I’ve been running a water cooled 80 mm spindle with similar weight for 6 months. It is not an issue. Ran the same spec spindle for years on a belt driven s3xxl with our issue other than increase belt replacements.
And the z axis in the 5 pro is not a z plus. It’s a ball screw hdz.
Your spindle will drop when power is shut off or the e stop is pushed fit to the weight of the spindle. I just have a wooden block to keep my bits safe.
You’ll also either need to modify a spindle mount or make an adapter plate to mount it. Carbide does not make an 80 mm mount at this time. I chose an adapter plate out of aluminum. That I made on the machine with the trim router.
