I remember an earlier thread about a new touch probe not working. The user removed the cover on the bottom of the touch probe and a wire was pinched.
First make sure you have the touch probe hooked up correctly.
As Neil Ferri asked when you touch the clip to the probe does the led go from green to red. If you have no led light recheck your wiring set up and if that is correct check for a pinched wire.
