Hi all,
I have been using my shapeoko pro for about a month now issue free until today. I was making some cuts and everything was going fine until the last part i did. I shut the machine down completely to run errands and came back to power it back up and am getting some errors.
Specifically when i try to intialize the machine nothing happens, no motor movement, sounds or anything. Then i get the below errors.
Machine controller restarted unexpectedly and may be in a undefined state.
GRBL Error: homing failed couldnt find limit switch
None of this was occuring before hand and have never had this issue before. I have tried power cycling the machine and leaving it off for 15minutes. Nothing has helped.
Anything you goes might know for a fix?
Thank you
