Right now it would only be an option with the new electronics, which we hope to make available for the 4 and Pro.
It’ll be pretty good, but nothing is perfect. For most people, surfacing the Hybrid Table will be more than enough. If you want to really tweak it, that’s possible too, but we never do that on our machines in house.
I was in the market for an upgrade to a 4’ width of a machine, (currently own Pro 4 XXL). I contacted Carbide 3D in July to see if they had anything coming up in production. Naturally, they couldn’t disclose anything which is a shame because I would have waited. I did end up buying an Avid Pro 4848 which arrived last week. Carbide 3D will do excellent with this new design. Kudos! I wish I could have stayed in this playground.
Any idea when the Shapeoko 5 Pro will be back in stock? Likely to be after the late December lot?
Trying to coordinate a purchase of one of these machines for a non-profit - we were looking at the HDM but this machine seems more appropriate for our use-case.
With the lack of belts, is there any restrictions compared to the 4 series on the temperature range? I live around St Louis and we get lows around 0 and highs over 95 and higher heat indexes… would be mainly worried about storing in colder garage, probably running only when above freezing as I would be freezing too
For a point of reference: I live in Northern Illinois we go from -20F to 90F+ and my machines have always lived in a garage that is only heated (to about 45F) when I am working in there. No problems.
@robgrz, you talk about new electronics and GRBL in the blog post. Can we get any more details on what version of GRBL you are moving to? How many additional inputs/outputs did you add for expansion? 24V based IO?
I guess a kinda apples-to-apples from my experience running the HDM in my shop in SLC. We range from the teens to 110 F here. The only issue I had with he HDM and low temps is the BitSetter. I had to clean and switch to a PTFE lubricant for the plunger. I sent that info to the people at C3D last winter. The motion system itself experienced no issues.
Is the cutting area the same as the stated machine? e.g. 4’x2’ machine has a cutting envelope of 4x2 with say a V bit cutter, or is the 4x2 only with a fly cutter/surfacing bit?
That’s reassuring to hear that that’s been your experience with the 4, since it hasn’t been mine with the 3. Definitely looking forward to an upgrade in the near future :).
My one complaint with the Shapeoko Pro has been that I can’t set and forget a mechanical zero if I want to batch out numerous products from a consistent start point upon turning the machine on and off. Anyone know if the ballscrew drive system would solve that issue?
That sounds like a possible mechanical issue. I’ve never had an issue running from the same zero location unless I’ve skipped steps and didn’t re-home.
Maybe this has always been the case, but this really impressed me:
For the first 30 days that you own your machine, we’ll replace or repair any Carbide 3D-branded item that gets damaged, even if it’s your fault!
I don’t know how many people on the fence about buying a machine don’t do it because they think “eh, I’ll probably ruin it in the first week,” but still, I really applaud the gesture/offer. It is a bummer when you inevitably make a mistake, and I think it’s really cool to give someone a free “boo boo” or two while they’re learning.
The rest of us can convince ourselves that battle scars are cool
