Is C360 free machining brass too much for Nomad 883?
I am planning to mill a custom watch case from C360 free machining brass bar stock that is 0.625" thick. Is this too much for the Nomad 883?
http://www.onlinemetals.com/merchant.cfm?pid=19794&step=4&showunits=inches&id=1296&top_cat=79
If not, what are the recommended settings to successfully machine this material?
As far as I can discover from online sources, the Brinell scale hardness for 360 brass is 141 and the 6061 aluminum used in the following video is only 95.
However, I do see that Apollo made a project from brass, though I don’t know which kind:
Is attempting to machine a watch case from 360 brass stock a bad idea?
Apollo did a bunch of brass at one point but you’re right, it is harder than aluminum. I think the brass we did was old stuff we had in the shop so I don’t know what kind it was. It’s worth doing a test cut with C360 but just remember to take shallow cuts.
-Rob
