Is there a way to turn on Smoothing so code is more optimised?
Hi Guys,
Is there a way to turn on smoothing in Carbide Create Pro, I trying to get more optimised gcode and align the software more to my machine which is a custom build.
I having loads of issues with random lag between my computer and controller and Openbuilds have stated;
If Carbide has a ‘smoothing’ option, turn it on. Set the limit to 2x your machines step size.
So my OX has a step size of 0.025mm, I set smoothing to 0.05mm (sometimes bigger, but never less). This means that every vertice is within a step or 2 of exactly where it should be. Ordering the machine to go to 0.001mm resolution is pointless as the steps are bigger than that.
I have a step size of 0.005, so would want smoothing at around 0.01
Regards
Chris
This site is mainly focused on advice to Carbide3D machines.
Since you have a machine “custom” they may not be familiar enough to aid you with your situation.
Does your controller run GRBL? Whats your arc tolerance set to?
Where is arc tolerance set? Is this Carbide Create, Carbide Motion or GRBL?
Arc tolerance on my Pro is $12=0.01
my little laser burner is $12+0.002
It appears to be a Grbl thing.
Hi David,
I’m using an Openbuilds Blackbox, GRBL, 1.1, my $12 is set at:
$12=0.002 ; Arc tolerance, millimeters
My stepper are lead screw, settings are;
$100=200.300 ; X-axis steps per millimeter
$101=200.300 ; Y-axis steps per millimeter
So using the calc I was given 1 / stepspermm = mm per step, my step per mm = 0.0049
So should I be setting $12 at 0.01, roughly double
Regards Chris
