Hello,
I can’t seem to be able to up load video. Anyway when the machine max out on each axis it seems to bump into the limit switch twice before moving on to the next movement. Is this normal? Thanks
If I understand what you are saying, yes, that is normal behaviour.
Yes, this is normal. It moves at a faster rate until it finds the switch, then moves away a bit and approaches the switch slowly to get a more accurate position of where the switch triggers.
Thank you for the explanation on what’s going on. Didn’t notice it in the set up video.
