Issue with Rotate function in Build 743
Issue: Rotation not retained after clicking Done.
Steps:
  1. Select object while on Design tab
  2. Select Rotate feature
  3. Enter desired angle of rotation in Angle field
  4. View that object has rotated to the expected angle
  5. Click Done
Outcome: Object returns to original orientation
Clicking Undo/CTRL-Z will apply the rotation that was visible before clicking Done, but it’s not the expected action to achieve the result.
Thank you.
I can not repeat the issue in Build 743. Functioning correctly when following your steps.
What OS are you using?
I forgot to list I am running the Mac version on a MacBookPro, Ventura 13.1. It behaved the same way on earlier OS versions.
The issue appeared with the V7 update, V6x did not do this.
On my CC 743 I enter the angle and hit done and the object rotates. I am running windows. If I hit enter after setting the angle and then hit done it goes back to original angle.
What seems to be happening is tapping enter applies and pressing “Done” re-applies.
Using tab, doesn’t seem to have this difficulty.
My QA skills are rusty, if not just :poop: to begin with.
Hitting Enter to apply the change is the step I missed and then Done closes the feature and changes the object to the last orientation.
