I just repeatly made the same project a present for my granddaughter and I have received odd results with missing letters or spacing errors. I thought I finely got it right and again issues.
Can someone suggest what I am doing wrong?
Can you post the file?
It looks like either lost/gained steps — did the dust shoe or something get hung up?
Maddy Gift.nc (384.7 KB)
Maddies Gift.c2d (2.2 MB)
Here are the files that I used thanks for the help
The previews for the .c2d file:
and the G-Code:
are fine, so this is a mechanical issue, either the machine got hung up, or there was a problem w/ the pulley set screws, belt tension, or eccentric nut adjustment of the V wheels:
I will check the item you recommended thanks
