Hello,
I am very new to CAD/CAM software, and CNC in general. However, I have been slowly figuring it out, but am stumped by this one. I have been importing logos from online, exporting them from Inkscape as a SVG., and importing them into Carbide Create. For some logos, I have no issues with creating a pocketing toolpath, however, I am having lot of troubles on others. For logos that have “spaces (that shouldn’t be cut)” inside the outer geometry, the toolpath generates as to where it ignores those “spaces” and runs straight through them. In return, it just leaves the outline of the outermost geometry. Any suggestions on how to fix this slight issue?
It looks like you only selected the outline, you need to select all the parts. If not then maybe the interior pieces are not connected (open corners and such).
When I tried to select all parts, and generate the pocket toolpath, the actual path would not load inside of the logo, and the sidebar read “calculating”.
