For some reason or another, when I first had Carbide Motion installed, everything worked fine. Ever since I enabled the “pro” version that was shared, I’ve noticed I can’t change many options in my Job Setup. This may extend into other parts as well, including the new model tab.
Did this coincide with a switch to a different computer or upgrading CC?
We’ve had issues in the past where it wasn’t possible to select drop-downs using a particular stylus implementation or touch — try updating everything and doing all the standard computer troubleshooting things. If that doesn’t work, let us know your system specifics at support@carbide3d.com and we’ll do our best to puzzle this out with you.
Well we tried everything and I wasn’t able to replicate the issue on my other computers. If anyone else has this problem. I decided to just use team viewer to connect to a computer the program works on. My main issue is that my work computer is the one having issues.
For anyone else, my computer setup: Intel 8700k/Nvidia GTX 1080/Windows 10 64 bit/ MSI z390M Motherboard
