dave2672
(Dave)
September 13, 2025, 6:32pm
1
Is there a way to rotate the project layout 45 deg? Like a 24 in x 24 in piece with one of the corners pointing up? I see how to rotate vectors, but not the stock size setup.
WillAdams
(William Adams (Carbide 3D))
September 13, 2025, 6:43pm
2
The Stock area cannot be rotated, but you can rotate geometry and position it relative to the geometry.
While it’s quite straight-forward to make MDF filler strips on an XL:
Geometry isn’t so kind on an XXL or Standard w/ their essentially square bed.
Making replacement filler strips requires that one do a bit of rotation to make things fit, and source narrow boards, rather than large sheets.
First, go to the local lumber yard and buy a board of suitable dimensions (greater than 40" in length, wider than 3" or so, and as close to the 3/4" thickness as is possible). One option is Azek “Exterio…
system
(system)
Closed
October 13, 2025, 6:32pm
3
