I work with small stock and so I’m often unable to use Bitzero, and instead, manually adjust to job zero. In doing so, does job zero factor to an endmill’s cutting diameter, or the bit’s shank diameter?
It seems as though if I use the #102, for which the cutting and shank diameter are the same, then things work just fine. But if I use the #122, which has a shank diameter of of 0.125" but a cutting diameter of .0312", then the cut is off.
I use a small piece of flat wood to try to align the X and Y axes to the center of the endmill, but have had varying success. Any suggestions for a better method?
Getting the Z axis is no problem, though, as I place a piece of paper on the stock, lower until the endmill no longer allows me to move the paper.
Depending on the small object you are milling, you could also consider milling a shallow pocket in a sacrificial material, then insert your stock/object there. That way you remove the issue of finding X0 Y0 completely. Just set them anywhere, mill the pocket/jig, and reference everything to the center of that pocket in the CAM.
