The ability to jog the machine while in pause during a job.
Set the “zero’s” and start the job but you need to be 0.003 deeper, so you could pause the job and manually add or remove as needed for position.
This is more than just jogging, in this case you’d also need the ability to re-home the Z axis.
I’m using a different controller and it allows you to do whatever you want when paused but it will automatically return to the last position according to the G-Code before resuming.
Just curious what controller you’re using Lucas?
I’m using an EdingCNC CNC720.
