I’m not sure if I’m posting this in the right spot, I bought some bits on Amazon.
I figure before I get really well versed in this machine, I’ll use cheap bits before I get nice expensive ones to break lol.
They didn’t come with any info on the packaging to show what to set the tool as, and now I’m not sure how to use them or select them as the tool being used.
Carbide Create does not support V endmills with flat (or radiused) tips.
You’ll need to either use a different tool, enter as a square endmill and use a 3rd party tool to get a 3D preview (or do w/o), or if the tip is small, use a feeler gauge to adjust Z-axis zero for the missing length.
I use Vcarve desktop but still have not found how to use the flat bottomed Vbit
I have seen videos where they use them to help clear away some material, I did not watch the whole video but I think I’d have to do two passes with one with say a 90 degree flat bottomed bit then another with a normal 90 degree else I would not get the sharpness on top of the stock cause the point would be missing
