Still need to add a few things to it…but, not to bad
Very nice job Michael, I particularly like the double doors. Congratulations.
Looks good ! Nice work.
Brian
I love how open is is with the two doors! hope you don’t mind if I copy that idea.
Looks Good. Are you able to leave the doors closed and “reach” the entire Y axis depth without the router hitting the front door?
Did you move the controller outside? Can you remove the cover for maintenance of your Y axis? It looks a bit tight on the sides.
