The layer panel is just 6 items. Do you know if I can make it bigger to show more items? I’m using a Mac. Also is there any way you can set the default for text?
At this time, the Layer palette cannot be adjusted in size.
It is also not possible to change the fonts which Carbide Create uses for UI elements.
Thank you. I thought I would ask.
