Have seen many issues posted regarding tool path left on the work piece or on the spoil board due to a couple factors such as speed/feed, dull tools, and even tramming. I’d like to have an option of using 1. default pocket pattern of starting the cut from the inner most center working outwards or 2. cutting either from the lower or higher end to the work surface and surfacing horizontally. I think this feature could be useful to many CM users and perhaps implemented into CC Pro.
I’ll second that motion. ![]()
Lace/Zig-zag/raster path would be really nice.
You can kind of do this with an engrave toolpath, but it wants to cut around the edges, and has a bunch of lifts.
You should be able to control the angle.
And I have to put in another plug for climb cutting!!! ![]()
A Raster would be really nice !!!
i agree also a raster cut would be better. I have set it up with a contour cut with just single lines across the piece to keep it with the grain. Next CC update Carbide 3d?
