It was my understanding that HOMING switches are intended to provide an automatic origin for the machine, and LIMIT switches are intended to prevent damage from accidental travel past the edges of the machine’s axes. But this kit only has three switches - wouldn’t it need six to act as a set of limit switches (one each end of each axis)?
Followup question: Is the origin that is generated by homing switches SEPARATE from the origin I set by zeroing all axes in Carbide Motion at the corner of my workpiece? Or is it the same?
In other words, to use homing switches, do I have to switch from using a zero origin on my workpiece to some zero origin on my SO3’s axes? or does the SO3 use a separate origin for homing/limiting than for working on a piece?
Thanks so much! Sorry, I’m totally new to this and am learning a lot.
What the homing switches do is give you an absolute position for your controller. You then set your zero separate, usually lower left corner in Carbide Create and Carbide Motion. The zero gives you a starting reference that you give the software based upon where you set up your work, like a jig that you fasten to your work surface. Your “Zero” can move while “Home” is absolute.
I hope I got that right…I’m kind of a noob too…lol!
Question regarding the the second set of sensors; I am also all new to this… just scratching the surface here…
Does mean that we can cut larger pieces with the CNC machine?! The only limit is the width, correct? ; then feed the machine with a larger workpiece ( lengths ) ?!
No idea if this is ‘right’ but what I did on a piece I wanted to make sure I could ‘find zero’ again was home the machine, zero it. Move it to my intended zero, then I noted the X/Y values. I was able to run both operations without shutting off the machine but had I not been able to I could have homed the machine, zeroed it, then moved the machine back to the position I noted. That would in theory have given me the ability to start again from the original zero.
