I use Universal Gcode Sender (UGS), so I can’t tell you exactly how to do this in Carbide Motion, but you need to go to the command line (I think it is called MDI window in Carbide) and type $$, then press enter. All of your settings will display. I recommend copy and pasting them to a text file using Notepad and save it for future reference. To make a change, go to the command line and enter the $# value you want to change with the new value and press enter.
For example, if you need to turn on homing, you would enter $22=1. You can then send $$ again to make sure the setting took.
Thanks! I will try the procedure.
