Losing connection
Hello everyone, I have some troubles with connection.
I have a shapeoko xl from 2021 and never have this issue. Machine loose connection and I have to initialize again and again. Then loose connection. I checked cables and I dont know why. Should I updated software? Could be something on the motherboard?
Thank you
Usually if this arises after a period of successful operation it is caused by the carbon brushes in the trim router wearing down.
Check and if need be, replace those, if that’s not it, check for a heavy load on the same circuit, and static electricity/grounding.
