Hi has anyone machined blue foam before? I want to machine some on my nomad.
Has anyone got a toolpath please?
Thanks
Tim
Thanks
Tim
Yes, it’s easy to do (messy) and you can run at pretty much top speed.
Thanks @mikep, does the foam hold its form as good as hardwood? Are the fumes toxic if there are any?
This is a little side project to my boat build.
Thanks
Tim
As you aren’t melting the foam like you would with a laser, there shouldn’t be any special fumes that would be different than if you cut it with a knife. It’s a mess though.
Does it hold form as well as hardwood? That’s a complicated question. It will cut nicely with the right bit (upcut single flute?) and have nice clean edges, but your ability to reach deep into a block is limited by the length of your endmill. Cutting forces should be very low, but you can still get some ‘whipping’ with a long endmill if you run it fast.
Foam is foam - as a material it won’t be as durable as an oak part, but if you’re using as a plug for making a composite part, it should be plenty strong for that application.
If you need something more durable, use Renshape (more expensive, more like wood), or even HDPE.
Thank you, very useful I have a long ball nose end mill. I will give it ago, I am using it as a plug.
Thanks
Tim
