I have my Z zero set to the appropriate depth and motion reads 0 for the z access. When I run the program the router goes to the correct x and y, but stops .67 inches above zero. The z readout reads at .67.
I’ve checked the thickness of my job in CC, and that’s correct. Nothing blocking the path.
It ran fine on the last job I did so may be related to the job but I can’t figure out what. Any thoughts?
I do have bitsetter on my machine. It runs as the program starts so the device knows the length of the bit
Where is the origin set in the file?
https://carbide3d.com/hub/courses/create/job-setup/
and how is origin set relative to the stock:
https://carbide3d.com/hub/courses/running-shapeoko/movements-zeroing/
I find that opening the .c2d file up and drawing a box which matches the specified dimensions (draw up the cut in profile if need be) or moving the machine to the origin and then using a tape measure to measure out the dimension(s) in question will make clear where things aren’t lining up.
Le Sigh…I was using zero height at the bottom…duh! Thanks for the help!
