trying to machine the wrench using the provided stock. doesnt look like aluminum. its a grey plastic of some sort ? anyone know if its supposed to be an aluminum plate or did i get the wrong stock with the machine ?
its a bendy grey plastic with white plastic stuck to it which peels off along with the carpet tape.
Trying to machine the wrench using the provided stock. doesnt look like aluminum.
What came with my machine looked like Alumalite (marvelous stuff; use it for the walls of my enclosures), an aluminum composite material. Clearly not Al alloy plate and not simple plastic.
mark
+1 on the Alumalite, @mbellon! I used it in my Tormach enclosure.
Alumalite is corrugated plastic laminated with thin aluminum face skins.
I think the sample piece is something like Omega-Bond (also from Laminators, Inc. who make the Alumalite) with a solid plastic core laminated with the aluminum face skins. At least on the Classic, that also appears to be the deck material beneath the moving table.
Randy
NICE ENCLOSURE!
Omega-Lite?
Yes, that is a better fit for what I remember.
mark
What you have is what we all got - so you’re okay
Cutting aluminum is tricky so it makes a lot more sense to start with a much softer material.
Are you planning to cut a lot of aluminum?
