I will try cutting without the bottom inserts on the next side.
I had also changed the facing angle to be ~4 degrees off the grain angle per @WillAdams suggestion. That seems to clear the small remaining edges I was previously getting.
Edit:
I removed the bottom cutters, which worked well. Thank you.
The chips looked significantly thicker.
The machine “felt” the effort, but no problems.
BTW:
If you try a DOC of 0.2 inches at 120 ipm and 12K rpm with Red Oak. A Pro 5 will skip a step of two.
Oops
First time I didn’t have the lines, and I’m super excited that it finally worked. No burning either. No skipping on the steps. Oh and I have the Pro XXL with the VFD Spindle.
