Media about shapeoko 5 skipping steps
More of a general thing - I’m going to be unboxing my shapeoko 5 this weekend at last, which is great!
I’ve seen various posts randomly dotted around about how the shapeoko 5 skips steps and certain people being upset. Does anyone have any information on this rumour if this is kinda a generally known phenomena I’ve missed - so you can either put my mildly concerned mind at ease or to validate the hear-say?
The majority of the cases (maybe every case) we have seen are:
  • Lack of lubrication/maintenance.
  • Using speeds and feeds from a cutter vendor that are made for industrial machines, not a Shapeoko-class machine.
Having run the FB Group for going on a decade, I 100% agree with @robgrz.
More than half of the time the linear rails and bearings are dry on a machine that has not been maintained properly. Also, the machines look to ship with an anti-corrosion grease on the linear rails. Getting some proper waylube (they recommend Mobile Vactra #2) in the bearing blocks and on the rails after assembly is a good idea.
People pushing the machine harder than it is capable of. It’s what I would say is a prosumer (pro consumer) class machine. If you try to go too fast, too deep, have a dull tool (it has happened to me), or stall a spindle…thus causing skipped steps.
Another one is that the owner does not square up the machine during assembly. That can introduce a ton of friction that causes skipped steps. I admit his has also gotten me. After squaring up my V1 HDM I went from frequent skipped steps in Y, to none in months.
another though that almost drove me crazy: deep narrow cuts. And then an downcut bit. The bit pushes down chips and dust, and gets stuck, one can happen: the bit pulls itself downwards, and out of the collet, causing an erratic deep cut, what of course cannot be managed by the hardware any more. Another can happen: the dust/chip pile blocks the bit from being moved forward, skipping steps and causing a desaster.
To avoid this always design pockets with at least 1.5 times the width of the bit for contours, or just for slots at the size of a bit use the next smaller bit and design a pocket.
Believe me, I was there. And still last night I cut a tray with a pocket as a contour, cut with a roughing upcut bit: still the dust was compressed that hard that I had to scrape it out with a screw driver.
CICworkshop videos provide some speed and feed recommendations from a lot of experience for wood, although from an industrial production approach to save time.
