The metal wheel that the z axis belt runs on seems to be touching the aluminum x axis causing small filings to gather near x belt
The z axis guide wheels are fully engaged and turning when the z axis is moving along the x axis .
Is there a way to adjust wheels so metal idler wheel doesn’t touch the aluminum.
You should be able to loosen the idler wheels, push them up and then re-tighten them.
If that doesn’t work, let us know at support@carbide3d.com and we will do our best to work through this with you.
