Drying wood:
I let it run at 220f overnight:
should
(Drying the wood in your home oven seems fine to me, but final cure once resin impregnated should
not be done in an oven you actually cook in.)
You can tell if your wood is dry by weighing it before drying, then weighing every few hours or so. Once the wood stops losing weight, you know you’re at 0%
Storing dried wood
Once the wood is dried, we’ve got to keep it away from all that awful water in the atmosphere.
The wood will pull in water if left out, so most folks wrap the wood in cling wrap, then shove that in a ziplock bag, and finally put all that in a gasket sealed Tupperware.
I’ve got a vacuum sealer, so I’m going to use that.
(Though water will still tunnel through the plastic over time. Monstrous stuff.)
I wanted to ensure I could open each piece without releasing vacuum on the other pieces, so the sealing is done with some intention. Each square is in its own sealed packet.
Going forward, I’ll probably grab a bunch of to those tiny mason jars and store them in vacuumed jars. That also allows me to see the pieces clearly when selecting them which is nice.
Since stabilizing requires a vacuum anyway and it probably moves air at 4+CFM, the jars should actually be pretty quick.
Automation ideas (autonomous overkill)
Since I’ve got a vacuum oven now, I’m thinking of tricking it out with a scale for weighing the wood.
The automation can monitor the vacuum and the weight, checking for changes over time. Once the vacuum and weight have stabilized, we can cut power to the vacuum and heater.
Since it will be a sealed system, it can sit there happily at 0% until I get around to sealing the wood.
I’m pretty sure I could just chuck the wood into the mason jars and put the jars into the oven. The vacuum oven is essentially a vacuum chamber, so as long as the jar lid is just a little loose it should act as a one way check valve. Allowing the vacuum to be pulled but sealing once the chamber is opened.
Auto sealing at 0% humidity in a nearly hermetic jar.
Pretty sick.
We’ll be getting to stabilizing soon
