Is there a minimum recommended font size for engraving with a 1/8 or 1/16 bit?
I’m trying to do simple pocket engravings of names in about a 3" or 4" , but can’t quite seem to find a font / size that will still look good that small.
for text, also consider using a V bit/vcarve… especially for smaller (< 2") text.
and the font really matters, some are much better than others (somehow I end up using cambria bold a lot… it does well both for v carving and for normal cutout)
I make 1" and 2" name plaques a lot, with a 2mm downcut bit (https://smile.amazon.com/gp/product/B073TXC45Z/ ) I get very good results
(for F&S on these bits, I use 20 ipm with a 12ipm plunge and a 0.04" depth of cut)
For pocketing text, you’ll need to select a font / size which admits the endmill — you may want to look into single line fonts:
https://wiki.shapeoko.com/index.php/Inkscape#Hershey_Text
https://wiki.shapeoko.com/index.php/CAD#Fonts
https://wiki.shapeoko.com/index.php/Commercial_Software#Fonts
Or, as @fenrus suggested, use a V carving, see https://wiki.shapeoko.com/index.php/Endmills#V-bits for a guide to matching size with angle.
