Missing Spindle On/Off Button
I recently updated to version 640 from a very old version 5xx after I upgraded to the HDZ. After setting everything up, the button to start and stop the spindle is missing from the Jog page. Has it been removed, or is something set up incorrectly? I have a Bitrunner (the old one.)
Did you select that you had a BitRunner during the install wizard?
Yes. But I also checked the option to prompt for setting the router speed.
This (spindle on/off as an interface element in Carbide Motion) was removed β€” use the Quick Action for warming up a spindle to test it (or enable the MDI) β€” please don’t power it on and jog around β€” safer to make a file in Carbide Create and send that.
I liked using this feature to make sure that the air and mist cooling are working as expected since the valves are controlled by the BitRunner.
Our recommendation for this would be to make a (or use an existing) Quick Action.
