I have just had a Nomad 883 Pro and I have a question about Multi-tool projects.
I have a lot of material that I want to get rid of on a project with a large end mill then do a pass with a small end mill for fine detail. How do I do this, is there a setting on MeshCAM that stops the job half way and then I can change the bit? Or do I have to run the projects fully twice to get the final result?
Hi @lnpurnell
You have a couple options, can you post a picture of the file?
In addtion to MeshCAM, you may want to try Carbide Create,
heres a link to a CC Roughing Pass discussion:
Without seeing a picture of the design, its harder to help, but heres a screenshot of MeshCAMs toolpath settings, Roughing settings are on the left, finish and pencil pass settings are defined on the the right.
