Multiple iterations of rest machining in CC Pro?
According to the website: “Rest machining allows you to use a second, smaller cutter to clean up a pocket after a larger cutter…”
Is it possible to subsequently use a 3rd or even 4th yet smaller cutter in the process? I’m considering a design which has an enormous range of pocket size.
Yes,
Just keep adding Resting tool paths.
