Pardon me for asking - If you secure the driver holder to the wall with the 4 mount locations, how do you get the drivers out? I’m simply asking because I don’t see a way to fit my fingers into the smaller driver areas and I would think to add a slot/keyway cut.
That is a very good question. If one were to push in at the top (they are rounded there), the bottom pops out a bit.
Now if that doesn’t work well enough, I can make some something like a battery puller, like you sometimes see in remotes or other electronic gadgets.
I’m putting some clear finish on it now, and I’ll give it “the ultimate” test tomorrow.
Awesome, that was my initial thought but it depends on the depth of the seat for the drivers to allow that range of motion. The battery puller idea is solid, I’m looking forward to what you come up with during testing!
