My Shapeoko 3 is not cutting on the toolpath
I purchased my Shapeoko several years ago. Set it up and have been using it (occasionally) with no problems. Recently I fired it up to make some simple parts from .230 plywood, but the dimensions of the resulting parts were not right. So after insuring all the V wheels were properly adjusted, I defined a 1" square and cut 2 of them. One specifying “Cut outside the path” and one specifying “Cut inside the path”. When cutting outside, the resulting square was .035 too short on both sides. When cutting inside, the ‘hole’ was .035 too big on both sides.
I had been using Create 743 and motion 566. Just upgraded to: Create 778 and motion 640. Same results for both.
I am out of ideas.
Post your files and photos?
Are you cutting a slot just as narrow as the tool? Try offsetting by endmill diameter and cutting as a pocket down to tab height? Leaving a roughing clearance and then taking a finishing pass?
Where possible avoid slotting and add geometry and cut as a pocket
and/or
I am not cutting a slot. As stated… for my test, I am cutting a 1" Square. I did fail to mention I am using an 1/8" bit.
@bikeopelli
Can you upload the test file for the 1’ squares for us to review?
Thanks for responding. In the event, I solved the problem. Well… sort of.
Since my original post I had tried several things. Everything I could think of even if it really didn’t seem like it might make a difference. No joy. Then it occurred to me to slow everything down and give that a try. Bingo!. Turns out that a feed rate of 20 and my router on the slowest speed solved the problem. What I don’t really understand is… for a long time I have been using higher feed rates and higher rpm and never seem to have this problem. Could it have something to do with vibration at higher rpm’s? Just dunno. In any case its working near perfectly now so that means “Case Closed!”.
@bikeopelli
Sounds like you didn’t solve the problem, you’re just compensating for it and now your projects will take longer to cut?
Worn tool or some other issue?
To rebuild a machine to pretty much like new see:
I’m retired… don’t care how long it take :rofl:s
