I needed a faster and easier way of loading my stock into my Nomad. Previously I was using a low profile clamp (Not Carbide 3D’s) however its bulkiness was unbearable. I lost around 75mm and had to keep my lexan cover lifted. First I modified my waste board with pockets to slot M6 nuts and replaced my old waste board with this (making sure to face the top). Next was to make blocks with a similar pocket that would act like a vice. With the bolts extended it’s very easy to replace the stock. My machine screws are even compatible with the wrench provided by Carbide 3D.
