Hi, my Shapeoko just stops in the middle of a session. It seems that it disconnects or Carbide Motion freezes or gets stuck. I have to restart C.Motion to get it to work again and then start all over.
Do I need a firmware update of some sort or what could be the problem? Anyone?
Hi @grrimbart
This is more than likely an EMI-related USB communication issue, I have collected a little set of forum tips here.
First order of action : ground your vacuum hose and router body.
Let me know if this helps
Do you have dust collection hooked up? Or are you using a vacuum when this happens? If yes to either question it can be static, I had this happen on a couple of projects, Either ground the hose if connected to a dust collector/vacuum or wait to vacuum until done.
Hi Grim,
I dealt with that intermittently. Mine was fixed when I added this EMI accessory, 100% fixed.
Eric
Thank you. It seems that it was a problem with dust collector and the static it produces. I’ll bookmark your list for future problems
