Went to the big box store to pick up some maple. Had a project for a customer. They actually came over to inspect the grain layout. ??? OK ??
Very simple pocketed frame. I am fat dumb and happy with a simple job. The project started on the pocket, almost finished I hear a weird sound. Hit a pocket of sand.
Toasted the bit and the piece is toast because of the depth of the sand.
Love nature. I should go back to fishing. The lures are cheaper
A couple of months ago I was planning a piece of rough cut maple to make a sign. I heard an awful noise and in the middle of a piece 13" wide maple was a nail or staple. This was no where near the outside of the board so maybe when the tree was younger someone was holding up a fence wire maybe?
Luckily it did not do any real damage and I extracted the metal and kept going. I was able to patch the hole later.
I have thought about buying one of those cheap metal detectors because I use a lot of rough cut lumber.
@Zman Nature does not hate you it is simply reminding you that it is in charge and our illusion of being in charge blows away in the wind.
