Need help X axis bogging down
I’m having some truble with the X-axis on Beaver Pro. Not sure if the issue is with Masso or pssibly the stepper. I ordered closed loop steppers. Hopefully, some oil and the new steppers will fix the problem. Here’s the link to the steppers I have on order. Do you think they’ll do the trick? Also wondering why the beaver pro products thread has been locked out and no new post can be added.
New steppers
automationtechnologiesinc.com
High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo…
High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components.
Current config for the X axis
IMG_0113 (1)
Old steppers
omc-stepperonline.com
P Series Nema 23 Bipolar 3Nm (425oz.in) 4.2A 57x57x114mm 4 Wires Stepper…
Nema 23 Bipolar 3Nm (425oz.in) 4.2A 57x57x114mm 4 Wires Stepper Motor CNC - Nema 23 Bipolar 3Nm (425oz.in) 4.2A 57x57x114mm 4 Wires Stepper Motor CNC - Electrical SpecificationManufacturer Part Number: 23HP45-4204SNumber Of Phase: 2Step Angle: 1.P…
Price: 34.60
Old stepper drivers
https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.amazon.com%2FKL-5056-20-50VDC-Digital-Bipolar-Stepper%2Fdp%2FB07MDLK27K&psig=AOvVaw0SXbTv_XbKfoXjWjGb-lQE&ust=1604967627677000&source=images&cd=vfe&ved=0CAkQjhxqFwoTCJCLtLyY9OwCFQAAAAAdAAAAABAF
PS. I’m using the standard 1m ballscrew setup you recommend in the BOM. See attached. Untitled 4.pdf (2.7 MB)
Here’s the file I was cutting 1001_Test Cut.nc (83.4 KB)
I have sent you another PM.
