Hello All,
I trust you’ve all had a peaceful family time over the holiday season.
After a wait of almost 14 weeks, the deities have looked very favourably on me. My original order was for a BitZero but there were some hiccups along the way. Anyhow, Scott of RoboSavvy and Support at Carbide have worked together, and I now am the delighted owner of BitZero V2. That was an unexpected and very nice surprise so a huge Thank you very much to all concerned.
I went to hook up BitZero (I did not connect it while I was checking BitSetter) and was dismayed to find the Z axis (Z plus) will not descend from its home position more than about 1 inch. It produces an error message in CM which I have not recorded. It was working fine the last time I used the machine about 8 days ago. Is it possible to obtain the error logs from CM if it is not connected? If not, I will retrieve them in the morning because it is -2 at the moment and I would prefer to stay
inside the house right now.
When I disconnect the BitSetter, everything works as expected. I suspect that this is just some newbie stupidity on my part and I need a tiny nudge to get me back on the rails and keeping up with the program.
Would someone please provide me with an insight into the precise workflow I need to be using so that I can enjoy the benefits of using BitSetter combined with BitZero on every job?
All answers greatly appreciated. Thank you.
