Hello,
I have a Shapeoko 4 and purchased Carbide Create Pro… I’m not really sure where to begin for learning how to do 3D texturing and whatnot.
I want to create a moon with some basic craters and such. I can create the file in Cinema 4D, Rhino 3D, Illustrator or Photoshop but I’m not sure what I need for resolution and such.
I’m cutting a circle plaque, with a moon texture in the background, and I’d like some raised flat/untextured lettering.
Any advice would be very much appreciated!
Thanks,
Jordan
WillAdams
(William Adams (Carbide 3D))
August 25, 2021, 12:10pm
#2
For a moon texture, you have a couple of options:
draw it and approximate it using the texture feature and possible some V carving and other toolpaths
draw it, and 3D model it in Carbide Create or some other program
source a b/w pixel image depth map which can be imported into Carbide Create Pro
source a 3D model of the surface which can then be cut using a 3D CAM tool or converted into a depth map and imported into Carbide Create Pro
One approach on this at:
Terrain Relief Models, Unabridged
[IMG_20190415_104354-01]
When I was musing about picking up a Shapeoko, the project I had in mind was carving a terrain relief model of Mount LeConte in the Smokies, and in my head I also had the trails engraved onto the model. In the quest to make this thing in my head a reality, I followed various trailblazers, perfected workflows, had epiphanies, scrapped entire workflows, wrote some plugins, added a laser, and eventually arrived at what seems to me like a…
Thanks Will! This is really helpful. I’m going to experiment with all of these possibilities.
system
(system)
closed
September 24, 2021, 9:08am
#4
