The toolbar w/ the “Upload” arrow appears each time you do a reply — this may depend upon permissions — I’ve upgraded your account, so if that was it, you should see it now.
You can e-mail a file in to support@carbide3d.com
sorry to ask so many questions, but I cant find any database to search. You’re my only source.
In “polyline”, is there a way to input length and angle with keyboard? The mouse is not accurate or controllable for precision.
when each is selcted, i see the “midpoint” on the central hegaxon sides, and on the connecting end of the long rectangles. But the two “midpoints” dont snap together.
Spiraphone 4.c2d (50.1 KB)
Okay, we got a sketch at support@carbide3d.com:
so to re-state the problem, we want 12 rectangles, of increasing size, which are radiating out from a central circle, so that their increasing distance creates a spiral.
Since we don’t have dimensions, we’ll start w/ some arbitrary ones in a drawing program which has a feature which will obviate that need.
I sent files from your Carbide that are dimensioned, but it seems you cannot select a rectangle and see it’s parameters, except sometimes (4 out of 12 show the parameters, 8 do not)
EDIT: As noted below, the .c2d file above contained a set of rectangles which were supposed to be the correct dimensions, so was used instead of the proxies which were to be be made, eliminating the need for the work-around in this post.
Import the pixel image as a background for reference:
We draw a pair of objects to get a rough approximation of size and rotate them to the same orientation:
and use them to get a pair of rectangles equal to the largest and smallest size:
which we then blend together so as to get as many rectangles as are necessary in a series of graduated sizes:
which we then export as a vector graphic which can be imported into Carbide Create.
Rectangles cease to be rectangles when they are rotated.
You can use this set of instructions w/ a set of actual files presently.
Alternately, we import the .c2d file:
and unrotate all the rectangular elements:
We then stack and align them all:
And position the dodecagon in the center and the collection of objects relative to it:
However, this will all be much easier if the Stock area is symmetrical:
We then select the stack of rectangles and use a Circular Array:
Then it is simply a matter of deleting the unnecessary objects:
and off-setting by the amount which one wishes to have around the rectangles:
And then drawing a Curve object to create the desired spiral — probably the easiest way to do this is to Node Edit the offset geometry:
deleting the unnecessary nodes:
and smoothing out the balance until one arrives at:
Attached as a v7 file.
Spiraphone 4_v7.c2d (56 KB)
Please verify and adjust as necessary.
wow - thanks …
My apologies, mean to go back and remove that post, since I worked up a set of instructions using your .c2d file, so instead, it is obviated.
One further consideration — got the ordering backwards, so the entire thing will need to be mirrored horizontally:
(dupe the central part, or draw larger, symmetrical surrounding geometry so that it can be re-aligned w/ the stock if need be)
I think I know what you’re referring to. I use the Boolean functions a lot and have it leave the original. The idea is then to delete the original. However, I still find open vectors which is what you are referring to. Turns out I missed one. Because they are on top of each other, I can’t simply select the open vector to delete it. If you’re doing an offset, you might be able to zoom in real close to see the open vector. The other option is to show nodes and drag one from the open vector down a bit. That lets me pick the open vector easily. If I’m correct, moving the node of the open vector will uncover the black closed vector underneath.
