New VFD install
I just installed my VFD I’ve had for a couple months and have ran into some issues. It powers up and turns on and off with M3 and M5 but it will not change speeds, it ramps up to 24000 rpm. I have re-installed the machine several times to no avail. Help
I figured it out. Apparently just changing to the VFD doesn’t get rid of the bit runner configuration. You need to change the option back to compact router, unselect the bit runner and save, then select VFD and save again. Works fine now.
