I just received my new shapeoko xxl but delayed getting bits because I want to search quality bits that will work for what I need.
What I need it to do:
Cut right through 1/2" baltic birch, the tighter corners I can get the better
(mostly cutting cursive writing)
Wont need it to carve.
Thanks guys!
WillAdams
(William Adams (Carbide 3D))
January 29, 2019, 8:00pm
#2
We have some official recommendations at: https://docs.carbide3d.com/support/#tooling-support
The community has more at: https://wiki.shapeoko.com/index.php/Endmills#Long_endmills — sounds like you might want some long (in proportion) endmills.
Best detailing you can get though is with a V carve — see: https://wiki.shapeoko.com/index.php/Carbide_Create_Basics#Clearing_area_around_drawing
Adding to what Will mentioned. If you are cutting entirely through, you might want to consider compression endmills. They will give you good finish on bottom and top.
system
(system)
closed
March 1, 2019, 2:55pm
#4
