Is there a way in Carbide Create to copy and paste the same object numerous times? Ie. If I want to cut out 40 circles of the same size in a single operation.
Also, is there a way to to create angles in carbide create… 22 1/2…45 degree, etc
Well there is copy function in Carbide Create no paste. On the Mac you select the object(s) you want to copy and press Command C and it replicates the object. If you want to do it again, press Command C.
You can also make an object and rotate it by the number of degrees you require. The function is at the bottom, second icon from the left.
I hope this helps
Thank you Luc… I’ll give it a try.
