Last week right after assembly I did the initial setup in CM. everything went well and performed the hello test. Today was the very next time i turned on the machine and when initialize I get “door is open” when the cutter gets down to the back right. Any help?
Please check how all of your homing switch connectors are plugged in, and for any errant metal flakes grounding out any traces on your board — if you don’t find anything obvious to address, contact us at support@carbide3d.com and we’l l do our best to work through this with you.
