Designed, set to go. Traces but floating just above material. V Carve sign. Changed depth from .05 to .10, NO change. Using BitSetter.
Where is the origin set in the file?
Where and how are you setting the origin relative to the stock?
Could you post your .c2d file and step-by-step notes on how you are securing your stock and setting zero relative to it and managing all tool changes?
to Top of .75 stock.
in Create
4 Corners with rail, It does not move
Bit setter sets relative “0” I assume.
I’ve made several b4 with no problems.
Ill have to go back to shop to locate file and post.
I am not a master by any means, still learning~ Desire to make this my sole work line.
Are you sure you didn’t set the work origin to the bottom of the stock in Create?
