I’ve downloaded the new CC works just fine. However, today I was designing a new sign and went to look in the library for some images there were none there. With the new version were they removed or is there an issue with it?
I’m seeing them in Build 432 in Windows 10 (admittedly, I’m using build 1703):
Please try build 431 or 432 and check your system for updates — if everything is up-to-date and you continue to have difficulties please let us know your system specifics at support@carbide3d.com and we’ll do our best to help you sort things out.
Down loaded newer version Fixed it thank you
