Is there a guide for the Nomad 3 belt tension? All the references I found were for the older Nomad with the toothed belt.
Nomad 3 has no belts other than from the spindle motor to spindle.
As this is a stretchy belt (well, two) I guess they are self tensioning.
Yeah those are the belts I’m talking about. The spindle motor has some slots that would allow you to shift the motor away from the spindle to tighten the belts but there is no instructions on how tight/loose they should be.
I’m pretty sure @BradmanOH is asking for a guide on how to determine the correct tension, not HOW to tension.
Yes, sorry for the confusion.
I am looking for some guidance on how tight the belts should be.
