I’m running a job on aluminum and despite very cautious settings (DOC .0075) the end mill is grabbing the metal and stopping and getting g dragged around. It seemed like it wasn’t getting enough power because the LEDs flickered so I switched to direct power instead of battery backup. Didn’t help. I increase the spindle speed from 9200 to 12000, then 16000 all with the same result. Any ideas?
Using the suggested speeds and feeds from Carbide, 8 inch feed, 1 inch plunge. Square end mill. These settings are working fine on the shapeko with the same job (with the machine changed) right now. Seems to be a power issue with the spindle.
The Nomad isn’t suited to using 1/4" tooling in harder materials and there are not Carbide 3D feeds and speeds for 1/4" tooling in the Nomad for aluminum.
