Hey, So I recently tried to create a single line cut through the material on meshcam but the g code it kept generating involved with also cycling around the object which was unnecessary and consumed time, So I heard about USG on chatgpt being able create a g code file that involved with making a straight line cut. I
then hopped on USG and typed something in the console and this was when my issue started to happen where homing didn’t work at all. I finally fixed my initialize process but my only issue is when i try to JOG the spindle, it says hard limit has been triggered, (1) or even (2). here is my setting from carbide motion
Machine: Nomad 3
GRBL Version:
Carbide Motion 636
Machine Controller State: INIT
Grbl Cycle: Idle
“bitRunnerEnabled”: true,
“bitSetterEnabled”: false,
“bitSetterX”: -5.0,
“bitSetterY”: 0.0,
“bitZeroType”: 2,
“connection”: 4,
“lastConfigSent”: 0,
“lastProbeIndex”: 0,
“lastSizeOption”: 0,
“odometer”: [
“cleared”: false,
“minutes”: 24.932400000000012,
“startDate”: “2024-06-21”,
“travelX”: 19017.5247707963,
“travelY”: 26704.85478035081,
“travelZ”: 2660.29601252079
“showCarbideRouterRpm”: true,
“spindleType”: 0,
“travelX”: -230.0,
“travelY”: -225.0,
“travelZ”: -120.0,
“version”: 0,
“webhooks”: ,
“workOffsetX”: 164.476,
“workOffsetY”: 43.424,
“workOffsetZ”: -12.149999999999999
Maintenance:
Travel (km) 0.02, 0.03, 0.00, 0.42 Hours since 2024-06-21
Queue Empty
